Halbyrd
- Sep 21, 2004
This is a fairly esoteric question, but I figure someone in here might have experience with this. I'm trying to hook up the front audio ports on my case to the audio header pins on the AV-710, but I've run into a bit of a snag.
The wires coming from the header, rather than being locked into a single plug, are all separated, so that I'll have to manually match up mic+ with mic+, ground with ground, stereo L with stereo L, and so on.
The problem with this is, the pins on the AV710 aren't labeled, so I can't tell which is which. The manual is worse than useless, and I've little confidence in the Via Arena fora, so I'm asking here:
Can anyone give me a pinout diagram for the AV710 front audio header connector?
Much thanks in advance
