Originally Posted by EFN /img/forum/go_quote.gif Obviously it was necessary to enlarge the dock port to allow bigger sized iMod dock adapter (which contains caps). And I reckon that while they are at it they just simply enlarge the headout port as well to allow bigger plugs yes?
that would be correct; with mine which is the same model. it doesn't even fit the standard medium size dock without caps and goes nowhere near fitting the larger capped LOD connector. except I didn't know they modified it for free, so I took to mine with a dremel. not as clean as his ;p
Originally Posted by Zarathustra19 /img/forum/go_quote.gif I haven't posted my rig in a while. I got a new skin from Skin-it to show my support for my football team.
Cheers!
And here we have the quickest and easiest way to remove all value from your DAP!
What you actually wanted to do was put a big picture of Christiano Ronaldo on there...
Originally Posted by Baba booey /img/forum/go_quote.gif rockbox no the Clip...how functional is it? and since you can't use games, what do you gain out of it??
Some people prefer the interface. There is a MUCH better EQ, crossfeed, pan/balance, a ton of other audio adjustments, folder browsing, and I'm sure I'm missing some other stuff.
