Zink
- May 12, 2010
It sounds like you take the earpads off by stretching the elastic that attaches around the housing of each driver. Underneath there is foam that supports the earpads and slightly muffles the drivers. Apparently there is a small section of foam right under where the mesh grill is that can be removed, leaving a ring of foam around the outside but a direct path between the driver and your ear, leading to a brighter sound signature. You'd then put the earpads back on and listen for a while to see if you like it better for long term use.
