Prolificaudio
- Dec 6, 2014
Can anyone tell me how the x2 compares to the hifiman he 500?? Which one has better bass and sq?
Dude are you in Logan?? Is this my clone brother??
I would say that there is some scale to be had with the x2. Neutral amps and sources tend to work better than warmer ones IMO. I only had the fiio e10k when I first got the x2. Then a week later I switched over to the uberfrost and Asgard 2 and it was a pretty large leap forward.
The fiio tended to overemphasize the bass/warmth and it was somewhat too bassy. The Asgard is a very clean, neutral amp with a very slight warmth to it and it matches very well with the x2. The bass now hits hard and tight and sounds fantastic IME. There dynamics are also better on the schiit stack. This stack may be more than what the x2 needs but man does it sound wonderful.
I've owned a Vali in the past..should be fine. I've tried with the Magni 2, Asgard 2 with no issues.
Thanks for the input. I just don't want to drop the coin and then have issues with the noise floor. I guess I could pick up a Magni2 to go with it.
