dsavitsk
MOT: ECP Audio
- Aug 3, 2003
Back from a short trip ...
Does this mean not connecting the grounds of the power supplies where they are, but instead conecting the ground of the TDA'a PS to the ground plane? Where would bea good spot for this?
there is no decoupling cap. It is a 1M resistor
Done.
In fact, there are spots for inductors all around.
The screws are M4 size. The mechanical drawing of the screws shows an 8mm head diameter. In a pinch, I'll use a plastic washer.
So, other than the issue with the ground, I think this is about ready to go? Any more thoughts?
Originally Posted by Francis_Vaughan The point about the ground returns is interesting. In effect we are making the ground-plane the ground reference, and therefore we should probably take separate ground runs away from it for any connection. In effect the ground-plane is the centre of a star ground. So indeed, separate runs for the ground returns for the two separate power supplies. |
The trace to the HOST pin on the 2707 (the one run though the bottom left corner of the chip's pins) could actually be run from the other side of the pad, and then around the outside of the de-coupling cap for the pin next to it. This would enable you to get the de-coupling cap closer, which is always good. |
It also strikes me that there is no reason why a medium value inductor or ferrite could not be put in series with the HOST pin trace. |
Done.
