lee730
- Jan 9, 2011
Just thought I'd resurrect this thread with an update.
Using Grumpy's tips from above, I've created my playlists for the AK100 in Media Monkey, exporting them as Playlist.m3u. Then loaded the files into Windoze Notepad. Using the find/replace tool, I've swapped the paths from the Windows paths to the correct paths on the AK as per above.
EG.
..\AK100\Music\Folder\Filename.mp3 => /nand3/music/Folder/ etc. AND,
..\SD Card\etc... => /mnt/SD1/etc.
You can use Replace to change all the remaining backslashes to forward slashes too. Takes just minutes to swap.
IMPORTANT! You must save the renamed file with a .pls extension and change the format from UTF8 to ANSI in the drop box of the save as dialog box.
And, I think some non-standard foreign characters like umlauts and acutes in folders or filenames aren't recognised by the playlist code even though they play in the AK100 from the library and folder sources. I've simply changed these paths where they are imported greyed out in the playlist.
Took a little experimenting to get this right but seems simple enough.
200 playlists! You'd want a script with that many. I've never had more than 10 or so and decided to start from scratch with the AK100. I stopped at 5.
And writing scripts may be over the heads of some of us older guys let alone the patience to organise 200 playlists. You must be incredibly organised Jim!
This sounds like an insane amount of work to get playlists on the sd cards
