Yikes
- Jan 26, 2004
I'm getting ready to recable my K701's with some Crystal Cable that I obtained. I have been searching for someplace to get Molded Strain Reliefs or Molded Cable Grips or Strain Relief Grommets that would be suitable. The Crystal Cable is small wire, the O.D. is only 1.75 mm so it's a small molded item that I'd be looking for. I've found places that will make custom pieces, if only I needed Ten Thousand.
I've also considered going with a small plug and jack arrangement such as that used on the K-702 but I haven't found a supplier for that either.
Any help would be appreciated.
