Syzygies
- Nov 16, 2004
I am experimenting with PIMETA output resistors, not to reduce hiss, but to convert my Etymotic 4p earphones to 4s. Many of us who bought the 4p did so to be able to use them directly with, say, an iPod. We waded through reviews and manufacturer literature describing how the 4s, with 100 ohm resistance, was vastly superior to the 4p, but needed amplification.
Something besides hiss is at play here. I met the Ety engineer, he's a smart guy.
Meanwhile, I can't find any links on our forum that discuss this. Can one plausibly fulfill the 4p-to-4s 75 ohm conversion inside the feedback loop? What's the difference? Can anyone summarize this old debate, with a modern eye to the 4s issue?
I caved on my request for socketed output resistors outside the feedback loop, in recent board design review threads. I now regret this. It's much easier to experiment with socketed resistors than with changing output jacks. Rewiring my output jacks was my one nightmare of an otherwise incident-free Pimeta build, and it continues to be an issue.
Here's what tangent said for the META42, which offered both options:
Originally Posted by tangent If you are getting audible hiss at normal listening volumes with the source disconnected, put a 47 to 100*? resistor at R8 or R9. (This mainly happens with low-impedance headphones.) There are frequent arguments in the audio DIY forums about whether it's better to put the output resistor inside (R8) or outside (R9) the feedback loop, and I don't intend to try to settle the argument here. I suggest you initially jumper across both positions and only put in an output resistor if you have hiss problems. |
