Out of Balance..... Help!
Jan 18, 2019 at 4:35 PM Thread Starter Post #1 of 3
Share2Care
Hey Peeps.
I am confused with myself and need some clarity on the basics of balanced components and cables.... And non balanced components and cables....
Say I bought an IEM MMCX balanced cable with a 3.5mm termination, if I just had a non balanced component such as a mobile phone as an example with a 3.5mm jack would the balanced IEM audio cable still work?
Would I need to change anything?
The same question can be reversed with a balanced source can be used with a non balanced headphone cable??
Please enlighten me as much as possible.
Cheers
Jan 19, 2019 at 2:03 AM Post #2 of 3
You need an adapter plug for that, which can be bulky enough you might as well just have two different cables and use either as necessary.
For a few distorted and noisy seconds, then you can't use it with anything any more, since you just shorted the two supposedly separate L- and R-.
