my time i had te HA-2 I never experienced interference
Is that with a 6S?
Is that with a 6S?
Yes. That was embarrassing!
What I mentioned about the 6S in particular stands though. It is known to have issues that earlier iPhones do not.
I do not know how it behaves with the Oppo specifically although replies to my question earlier report minor problems.
I would proceed with caution and buy from somewhere that accepts returns. Or be prepared to use a previous iPhone.
I can confirm this, I own both an iPhone 6, and 6s, the 6s interferes with my oppo ha-2, and my edifier S730.
The 6 does not. The interference can be lessened by turning on bluetooth. Airplane mode doesn't seem to have an effect.
Yup, I'm on 9.2.1 on the 6s and 9.2 on the 6
I got my HA-2 about a month ago, when I first got it, I thought it was defective because of the bad interferes with my 6s Plus, I was on iOS 9.3 beta 1 or 2 back then? And when I was just about to return it, iOS 9.3 beta 3 (I think) came out and the problem totally went away as soon as I updated, and I read somewhere it was iOS' software issue with digital out which HAD happened before...
So, if you're on released version iOS 9.2.1? Updating to Beta should solve your problem, and iOS 9.3 beta 6 just came out as I type...
Ok, so while we're on the topic of iPhone 6s Plus with HA-2, I do have another issue.. I have a lightning short cable which I love, and it's supposed to be MFI, and it works just fine most of the time, but every so often, when playing music, the music would just stops on it's own, and a sec or so later, the handshake sound came on from the phone and it will be back to normal when I start the music again.
It's all random, sometimes, I could play for an hour without issue, sometimes, it would just stops 3 or 4 times in 10 minutes, and I even went back and exchanged the same cable from the shop already and same thing. No issue with the other brand's cables I have including the one that the Oppo came with, anyone else seen this before? Other than it stops at random, it charges and sync just fine...
I've had that issue as well with most cables. It seems to have varying degrees of frequency cable to cable. I have no idea what the issue is.
How do I get these beta updates?
Sign up with Apple here, and then enroll your device.. https://beta.apple.com/sp/betaprogram/
Thanks man. It did actually dawn on me to Google it! Any down sides? Glitchy? Thanks again.
