billhickok
- Feb 11, 2015
Also noticed that when I have the sample rate correct on MIDI, bit rate will show up correct as well. For example, sample rate set to 44.1 for mp3 and FLAC files with 16 bit, HA-1 show Audio Format as PMC 44.1/16. When playing HD tracks and adjusting MIDI, PCM sample and bit rate is also correct (192/24 for example).
This is true for me only to a certain extent...What music client are you using?
For example, I have Audio MIDI set at 44.1/32bit and when I use iTunes, my HA-1 correctly shows 44.1/16 with standard redbook Apple Lossless files. When I play mp3's of any sample rate/bit depth, the HA-1 always shows 44.1/32. When I play an Apple Lossless file encoded in 96/24, the HA-1 still shows 44.1/32.
Anything and everything I play using Vox (lightweight audio app) shows 44.1/32 on the HA-1.
Is there any way Oppo can fix this via a firmware update on their end or is it strictly a software issue?
Also, does BitPerfect remedy this on the HA-1?
