1wyseman
- Jan 2, 2016
Folder browsing is good to go after the firmware upgrade.
Thanks! Whew...what a relief.
Asian Band?
Thank you...I swear it was something I read on the interweb.
the battery life is bad and it will piss you off, you can close as many apps as you like and dim it etc, battery life on it is still crap.
the sound is great, but the equalizer is confusing.
the headphone socket is ok but not fitted as solidly as it should be
build quality is ok, not fantastic , talk of it being built like a battleship is bollocks, it isnt heavy and doesnt feel expensive.
small gripes - the track skip on screen next to the graphic display is an awful layout, and the equalization coming off the circle is also a crap design imo, it looks odd.
all in though, given the sound quality and what it is , it's a good unit, i like it but will have to learn to love it, but it's no 'endgame, thats for sure.
If your idea of fantastic build quality is weight then add a brick to it. Voila, you have the best build quality. Seriously, which DAPs do you consider built with higher quality than DP-X1?
How long is the battery life are you talking about?
Yeah the on-screen track skip sucks on the default interface. But do you know you can change the screen mode which has a different button layout. I hope you can also see or feel the hardware buttons on the right side. That too can be used to control playback. In fact you can also use third party music player app if that is not enough for you.
The equalizer, hmmn it's just personal taste. If it's confusing for you it could be a gem for others. Like the interface you can choose a 3rd party app.
You made me curious, so I took a look at my DPX1A and I noticed it was connected on my 2.4Ghz WiFi and wasn't seeing my 5Ghz WiFi on any scans.
So I set my DPX1A to 5Ghz only (in DPX1A advanced WiFi settings), then logged into my router and changed the 5Ghz channel from 149 to 48 and now my 5Ghz WiFi band shows up on the DPX1A scan. I set the DPX1A WiFi setting back to "Automatic". Both bands show up now.
Thanks for the hot tip!
Lol, I read that too on here, so don't worry; you're not delusional
I think it's something to do with different default settings on routers between Asia and the West.
A different choice of channel, or frequency or whatever.
If it's anything like my router, the solution is not to play with the router itself, but to open a browser on your computer, type 192.168.1.1 into the address bar and press enter/return. It should then bring up a login screen for performing administrative tasks for your router (hopefully login details are on a sticker on your router) and you just log in, go to the network screen and adjust the channel.
However, do read up on this on here (or elsewhere) properly before attempting this!
It should be straightforward enough as long as you're following good instructions.
Does changing the wifi channel impact anything else using the same wifi band like your phone?
@Layman1
Later last night I lay thinking in deep thought and recalled having to go 192.168.1.1 to change security settings or something.
@OneL0ve
But you did say everything (WiFi) was working from the start--before adjusting things, correct? Are you in the US?
@crims
Yes, exactly my question, too. What would changing something to accommodate my DP-X1A do to the many other things using the router?
