Riley Beale
- Jul 9, 2016
Can anybody comment on Onkyo's customer service specifically in the United States?
I still do not know how to proceed. What I want to do is buy some very good quality full-size closed-back headphones that I can directly connect to the balanced output headphone jack of the DP-X1, which the user guide specifies as 4-conductor, 2.5mm.
I think I have 2 options:
1. I could buy headphones which are already wired for balanced use. The only one I can find so far is I think the Audeze LCD-XC. Any suggestions as to others that are full sized and closed-back would be much appreciated. I would then need to buy a cable to connect the headphones to the DP-X1's balanced output headphone jack. I cannot find any. Any suggestions for something in the $100-$300 for a 1.2m length would be most appreciated, and any comments on sound quality would be great.
2. Buy good single-ended headphones eg AKG K872 and convert them to balanced use and buy a cable for the DP-X1. I am not sure who can do this.
Any help would be much appreciated!
Buy this headphones:
www.moon-audio.com/focal-elear-headphones.html
Pick AK 2.5mm TRRS recabling from the list in the same order.
He was asking for closed back headphones.
Do not buy these!
Got it. Sorry.
If closed-cans, do consider Ether Flow C and DT 1770 too.
Thanks. I already have the DT 1770 Pro but they are not balanced. Here is my thinking. Firstly, I understand that to fully take advantage of the DP-X1 features (dual chips etc) balanced output is optimal. Secondly the DT 1770 Pros are quite inefficient and are not the best match for the single-ended output of the DP-X1.
How about the Oppo PM3s, then buy a Forza cable.
M3u playlists work perfectly.
I am not super knowledgeable about playlist formats. Are M3U8 and M3U the same thing, if not, what is the difference. With my Fiio X5 I cannot get m3u playlists to work with the player or even show up.
They are basically the same thing. M3u8 is utf-8 encoded. I am pretty sure it will work. I did not check what format the m3u files were before i deleted them off my pioneer. I accidently transfered over playlists i did not
