I just picked one of these up used. It is the B version with no BNC instead of USB. I have been doing listening between my 3 dac/amps to really dial in to the differences. I also have a Schiit Fulla and an Emotiva Stealth DC-1. I really want to like the Sparrow. Its got a lot of power for such a small box. Now to be fair the Emotiva has dual DAC chips that run balanced which is going to produce a different sound than a single stereo DAC chip. The Emotiva being my reference point for really balanced, full sounds large soundstage; the Sparrow does not beat out that for sure. This is my first Audio-GD product that I have owned. I have always been interested in what they are doing as they are one of the last companies to be using the R/2R resistor ladder DAC chips. The sparrow of course does not have that chip nor because it is the B version the higher quality components.
I tested with Hifiman HE-400i and AKG K240 headphones. Source Macbook Pro Optical Tos-link out to the DAC/AMP. The music I tested with were 16 bit 44100 FLAC and 44100 512kb/s and higher MP3s.
Look and Feel
I really like the look of the black metal enclosure. Even though the pot is the lower grade one it still feels smooth. Though I can hear the channel imbalance at very low settings, these settings are not what I usually listen to music at. Comfortable listening is between 10 and 11 on the clock. The input switch does feel a bit cheap. Also it does not have a lot of weight so this could be put in a backpack and brought to and from the office or on a long trip. It is not portable in that it requires an outlet and is a bit big to roll around with at a coffee shop (Enter Schiit Fulla). It does not have a full splattering of inputs, like no analog in or out but I only use optical from my MBP anyway. Overall I think it looks nice in the stack.
Comparison to DC-1
The sparrow seems a bit brighter than the DC-1, with a bit less soundstage. The lows are less rich as well, seems like there is a bit of a roll off on the lower end. Things seemed closer into my head with the HE-400i (which have decent soundstage with just about any amp). When the bass gets heavy or the sounds get really complex and fast, i found that the sparrow was a bit blurry. I find the brightness to be more in the high mids to low highs. I did not find it brash or unlistenable though and as I can tell so far there is no fatigue with either systems. Overall imaging is fuller and more clean from the DC-1 but the Sparrow has decent imaging as well. Overall the polish and clean sound without rolloff on the low end makes the DC-1 the clear winner by a lot but also the DC-1 was $500 new and the Sparrow was $130 new. (DISCLOSURE: I got my sparrow used)
Comparison to Schiit Fulla
Having a single DAC chip and no balanced parts this is a bit more of a fair comparison. These two DAC/AMPs sound very similar. Both have a level of brightness to them. The Schiit Fulla has a bit more brightness and is a bit more fatiguing than the Sparrow. Also the rolled low end is present in the Fulla as well, though just slightly less. Of course with the Fulla being USB powered and the Sparrow being outlet powered the Sparrow has a much larger amount of power and thus what is 12 o'clock on the Sparrow is 2 o'clock on the Fulla. The pot is much higher quality on the Sparrow as well, though both share the low end channel imbalance. During some vocal tracks where the Fulla seemed to struggle with the higher and louder notes of the male singers the sparrow did not blink an eye. The soundstage are similar though the sounds presented up front (close to you) are a bit closer on the Sparrow. On the point of details I can say that the Sparrow does render way more detail in the good quality sources than the Fulla. The detail with the sparrow is fantastic for the price.
Overall I think the Sparrow is a nice and inexpensive amp, though it does not really beat out any of the equipment have it has a nice place as a DAC/AMP combo i can use as semi portable. In some ways it sounds like a larger and bit more powerful Schiit Fulla. I am not sure if it will remain a permanent fixture of my stack like the Emotiva DC-1 has earned but I think it is good enough for now.
I would like to compare this DAC/AMP to something like the Big Ego from Emotiva as I think that it might loose to that from what i have read about the Big Ego.
