- Oct 31, 2008
Yes, I received them a couple of days ago. Great sound. Good sub-bass with some mid-bass mixed in that doesn't drown out the mids and treble. However, there is an issue with them. The right ear piece has some very bad driver flex. It will even pop sometimes after insertion. So, I think I'm going to send them back to Amazon for a replacement. If the flex was only during insertion I might keep them. But, it's very annoying when it happens during listening sessions.
Overall though, for $15 can't beat them (assuming I can eventually get a set that doesn't flex).
well just so you know, driver flex isnt a problem persay, so long as the pressure equalises in your ear so they sound fine is whats key. also, giving complys a go can oft assist if having any sort of fit issue. though i grant a set of complys cost the same as the 600x's do
