- Apr 28, 2007
Well, This is where I'm not so confident in making a recommendation, as I'm still hunting for the ideal DAC, but I'm confined by my self-imposed rule of never spending more than $1000 per desktop component, including DACs, amps, and headphones (new or used, before tax and shipping). Still, that's a lot of money, as I have too many other hobbies where $1000 can go a long way, so like you, if I can build a system with less expensive components to get just as much enjoyment, I'm happy to go there.
My profile ehibits a bone yard of previously owned or still owned "low-fi" DACs and amps, but when it comes to DACs, I'm finding that cutting corners isn't as easy as with amps - especially for the HD800.
I tried the roughly $250 "Battery DAC" - an NOS DAC made in Paris - but found it to be too "smooth" for the HD800 - not enough resolution. And that's the rub with the HD800 - you can smear the details - using "affordable" tube amps and/or "affordable" NOS DACs - to make the HD800 sound less analytical, but you can easily go too far, depending on your tastes.
I've come to prefer allowing the HD800's strongest traits to shine, while reigning in that treble brittleness just enough to prevent fatigue in long listening sessions.
Believe it or not, right now, I'm caught between the Metrum Acoustics Octave MkII + Aurix being just a little softer than I want vs. the ES9018K2M DAC of my Oppo HA-2 + Metrum Aurix being just a little edgier than I want. I much prefer the Oppo HA-2 portable's ES9018K2M DAC to the ESS9018 DAC of the Oppo HA-1 - especially for USB input, where the HA-1's USB receiver seems to suffer from some internal power noise - just guessing, but it's somewhat grainy compared to driving the HA-1's ESS9018 DAC with Coaxial input from an external USB-to-SPDIF convertor (like the Resonessence Concero or even the inexpensive Teradak Teralink X2).
Whether using USB input or an iDevice (my favorite for maintaining a really low noise floor), the ES9018K2M DAC of the Oppo HA-2 is currently my favorite DAC for the Aurix -> HD800 (as well as being my favorite DAC for use with my iBasso PB2 portable amp > HD800.)
So, if you want to keep things affordable and kill two birds with one stone (a portable DAC that can also serve as a desktop DAC) get yourself an Oppo HA-2 for use with the NuForce HA-200. I'm not kidding. It's my favorite DAC at the moment - for my HD800 and every other headphone. I find that it has none of the treble "glare" for which ES9023 and ES9018 DACs are infamous. The Concero was the first DAC I had that proved this was possible (with its use of the ES9023 - which is particularly bad that way, as a rule. I attribute this to the Concero's spectacular power management, which lesser ES9023 DACs, like the JDS Labs Objective DAC (ODAC) simply don't have.
I really feel like I'm sticking my neck out and want you to know that it's just one man's opinion, but I think "most" people would like the sound of this chain:
Tidal HiFi and/or Onkyo HF Player > iPod Touch or iPhone or iPad (no CCK is required with any of these) > Oppo HA-2 Line Out > NuForce HA-200 > HD800
Both the DAC and the amp are neutral and transparent - allowing the HD800 to retain its greatest strengths without coloration or excessive softening. And if you read that link I provided in my last post, one of the traits I lost when I replaced the HA-200 with the Aurix was a better soundstage - another forte of the HD800 if you don't hold it back with upstream gear.
For use with my desktop amp, I use the reasonably flexible Audioquest Golden Gate 3.5mm to dual RCA cable, plugging it into the top of the Oppo HA-2 (Line Out jack), then looping it back under the silicon bands to affect a strain relief before continuing on to the RCA inputs of the amp.
I had done this previously when pulling Line Out from the excellent PCM1792A DAC of the FiiO X5, but it has such a troublesome UI that I sold it after buying the Sony NWZ-A17 - which is now my "card reader" of choice for use with the Oppo HA-2 - when I want to play FLACs from my library of microSD cards - again, through the Oppo HA-2 - using its DAC, not the Sony Walkman's proprietary DAC.
I had better stop or I'll be writing my entire audiophile biography.
Just get the HA-200 for now and move slowly. Getting there is half the fun.
Mike
Mike
