JaZZ
Hi Anders
All of the recordings have been left as they are, just crossfeeding was done, which may make for a minor alteration of sonic balance now and then, but generally is rather neutral and most notably doesn't taylor the sound to my headphone setup in any way.
It's funny: You remember, I have sent you five black Fujifilm CD-Rs and one silvery TDK CD-R. All of the «original» references are TDK CD-Rs. Now the recording which made the most obvious difference (PIL) was on the silvery TDK disc, hence the same as the «original» (in fact both are burned from the very same wave files), whereas the five others effectively were burned on different media. So one would rather expect them to cause the greater difference.
Next time I'll send you exclusively rock recordings and silvery discs to avoid confusion!
...I wondered a little about your sound edited albums, perhaps you had edited them to sound optimal in your current system, but I assume that then more editing than crossfeed should be required. |
I have never treated CDR's before and it is hard to see that these should differ from CDs. Maybe, black material could make a difference and one part of the tweak is to paint the edge black, maybe not necessary if the disc already is black and making the tweak less effective than with normal discs. |
