nice review morijinal
alright, i guess i would want to put a word or 2 of my own into this pair of headphones,well i took the same route as morijinal which came from the HD202 to the HD558
when i tested the headphones at the shop 4 months ago, i picked the HD558 over the DR150 due to its technical superiorities and its soundstage, i didn't know about the 'fun' factor (didn't know headphones had fun and soothing varieties at that time)
so when i pulled the trigger and brought these home i was almost half dissapointed, i played with the eq and tried to get it to sound as good as possible because it just didn't sound engaging. nevertheless i let it burn in over the next few days at moderate volumes. a day later i tried the foam mod and i loved what it did to the sound the airy feel of it was superb with its transparent, wide soundstage. i did have a dilemma between modded vs unmodded, but i picked modded because i missed the airyness of the sound.
2 months later i found out that my phone was a crappy source, and shifted my music listening to my laptop which was clearer and provided a better soundstage, then i managed to find a 250 band eq by accident after reading about the electri-q eq software around here. after extensive tuning everyday (it still changes now as i type) it sounds wonderful. one aspect i would pick on is the grain in the treble, i wish it had more detail, bass lacking concentration, and lacking adrenaline induced experience. so as a result of that, 2 weeks ago i bought myself an Alessandro MS1, mainly for portable & exciting use
comfort:8/10
very comfortable, but the inside of the ear touches the bulging piece at the back, can cause a little pain after a few hours (note my ears are small, they can fit completely inside the HD202)
build quality:7/10
cable detaches which is nice, the cable housing seems quite durable too, the headsize adjusters are quite hard to slide, no markings on it too(had to draw them on myself with silver pen), plastic seems quite nice and hardy too, though a little hollow feeling
sound quality
comparing to similarly priced headphones at retail price. again only in my opinion, do take this with some salt
highs:5/10
weakest point imo of this pair, sounds a little harsh and blunt, but its good that it isn't fatiguing at all (but then again i like grado treble)
mids:9/10
lovely mids, the vocals are very lifelike and natural
bass:7/10
the bass amount is right, but it lacks subbass and impact, but then again this gentleness makes it a very soothing headphone
soundstage:8.5/10
very wide and seperation is really good, though would be bested by some of the more expensive counterparts
overall impression:
soothing and very immersive, kind of surrounds you and seduces you into its musical depths
value: 6.5/10
not a bad value but not the best deal either,comfort, soundstage and mids are its strongest point, tonality maybe be too plain for the average modern music listener, and veiled it feels, detail and bass could had better from other headphones
without eq this pair would be less than ideal for my music which happens to consist mostly of EDM, i feel that when i remove the eq it becomes a little dull and muffled, but still sounds good for classical and instruments at flat.
add on: i do not know if burn in had an effect cause i was playing with the eq from day 0.1
