yoyowiggle
- Jan 10, 2014
Got my amp this morning and have been breaking it in. They have modified the stick-on feet to be a smaller ball shape. Mine came with 6BZ7 tubes. While the manual says to align and push down gently, this was not happening with my sockets. Even firmly pressing them after assuring alignment they did not fully seat though they made sufficient contact to work. This is my first experience with 6BZ7s and these are from Canada. I did try my Voskhod 6N23P Rockets 1978 Silver Shields that I was using in my Lyr and they seated fine. Therefore, the pins must be a bit thicker in these Canadian tubes or at least the pair I got sent.
While its too early to report on the sonics, having the gain switch is a godsend if you have sensitive headphones like I have. The result is dead quiet performance. Obviously, I can use more of the volume control though that has not been an issue in the past. Where it had been at 9 o'clock it is now at 12 in the Low Gain position.
One item that I did confirm was normal with Jason (he answered email on Sat eve! ), the Lyr 2 does run warmer than its predecessor. Therefore, make sure there is plenty of space above it. I changed shelf locations from where it had about 4" to 12" and got a 5 degC drop.
Time for some more listening...
I have had my Lyr 2 for a week now and love it!!! I had a couple Amprex, Holland, Bugle Boys that tightened up the bass and opened up the soundstage a bit. In high gain I have been listening with my 650's, in low, to PSB M4U1's and SONY XBA-4's. The Lyr 2 is dead quiet with all four HP's. I want to put in a few more hours with a variety of music before I elaborate on sound, but my early impressions are very positive, with the HP's on hand.
how bout some sensitive iem?
Mmmmm…. after reading these impressions, my wallet has started whispering tempting spending thoughts towards purchasing some new Schiit … Lyr 2 to be precise.
Well, Old Grouch, I see where your moniker fits ...... I was asking about the two HP's in context with your Lyr, my apologies. If I wasn't clear.
