Bredin
Banned
- Jun 23, 2009
Does the HPA have any fuses that needs to be switched to Furutecs rodium-plated ones?
And how much will a new battery cost?
Originally Posted by Bredin /img/forum/go_quote.gif Does the HPA have any fuses that needs to be switched to Furutecs rodium-plated ones? And how much will a new battery cost? |
Originally Posted by mrarroyo /img/forum/go_quote.gif My Isabellina HPA is past the 300 hour mark and it only has gotten better. Of the 300 hours I would say that a good 100 hours has been via USB and that is the way that I am currently using it. To me it is very involving the background is pure black and it has a level of musicality not achieved by many of its competitors. I presents the music in a wide and very realistic soundstage w/ draws the listener in. I ma so happy w/ it I am now looking at incorporating a Signature 30.2 w/ an AKG K1000. My wallet is destroyed! |
Originally Posted by mrarroyo /img/forum/go_quote.gif I ma so happy w/ it I am now looking at incorporating a Signature 30.2 w/ an AKG K1000. My wallet is destroyed! |
It'll play 24-bit music with no problem - and even files with higher sampling rates like 96k or 192k (but it does not oversample - it just plays at the sample rate that it is fed). |
Originally Posted by auee /img/forum/go_quote.gif mrarroyo, Glad you are enjoying listening with the Isabellina HPA. I have seen many of your posts, so I am aware that you have listened with many different amps and digital sources. Are there any separate DAC and HPAs that you would compare this combination component to? All the best. |
Originally Posted by tosehee /img/forum/go_quote.gif Also, can you elaborate on this? Does this mean that it can take the input from 24bit/192khz+ without any upsampling? The spec on the website states that it is 16bit NOS DAC. So, this statement is little confusing to me.. |
Does this sync well with HD800 in SE? |
Vinnie, First off....Kudos to you for a great headphone amp! i have two sennheiser headphones, the HD600 and the HD800. I have only listened thru the HD800 and my initial impressions are extremely favorable. From the moment i plugged in my HD800 and started listening i was like 'WOW'! Right from the get go i found the sound to be perfect. the whole range of sound coming from the Isabellina HPA from the bass thru to the highs are balanced in a way i haven't heard before thru any headphones or amp period. I have owned the Grace Design M902 and personally found it to be too bright and harsh. i have also owned the Davry Engineering DA11 and found it be too soft and lush(heavy sounding is my best thinking for it). the only other amp I've owned was the firestone Little Country 3 and Spitfire 24 tube amp/DAC Separates which i found to sound good but, i didnt like having to have four separate pieces including their dac plus all the associated cables and plugs to make it all work. Update: it has been 6 hours since i first started running my HD800 thru the Isabellina HPA with lossless WMA off my computer using the included USB cable. the soundstage continues to find me awed! i can't believe my long journery in search of the perfect amp, an all in one solution that sounds like the best tube amp you'll ever find, but taken one step further with a NOS(New Old Stock) DAC. I'll leave it up to Vinnie to elaborate on the NOS if any of you guys have questions on that end. Btw, my Isabelina HPA is serial # 002 I'll post again after i get to around 100 hours of burn in and let you know what i think. but at this point in time i see Vinnie becomming very busy building the Isabellina HPA's for the forseeable future. Again i want to thank Vinnie for a... let's see a (quoting 3dgameman.com here) Totally Kick Ass Product!! joe |
