Originally Posted by Vinnie R. /img/forum/go_quote.gif
Try refreshing or clearing cache... it should work fine
The update seems like it could use a bit of cleaning up.
"ALO Audio, a highly-regarded cable manufacturer, teamed-up with us and has created an iMod Dock Cable that has these capacitors installed in the dock plug of this cable. This cable is required for use of the 5G/5.5G and it MUST be purchased separately from ALO Audio. in order to use your 5G/5.5G iMod.
As mentioned above, the 5G/5.5G iMod requires the use of an ALO Audio iMod Dock Cable. ALO Audio offers a few different versions of this cable, and they are all of premium quality and are designed for specifically for the 5G/5.5G iMod (the Black Gate NX-Hi-Q signal coupling / dc-blocking capacitors are expertly installed in the dock plug of this cable)."
I think changing it to:
We have teamed up with ALO Audio, a highly-regarded cable manufacturer, to introduce the iMod Dock Cable. ALO has found a way to install the capacitors in the dock plug of the cable itself, thus it is required for use with the new iMod. You must purchase the cable seprately from ALO Audio's
website.
The ALO cable is required for use of the 5/5.5 Gen iMod. They offer several versions, and each premium quality cable has been specifically designed for use on the iMod.
With the bolded website being a link to the cables on ALO's website. I don't mean to sound critical, just thought the wording could use a bit of tweaking. I won't be offended if you don't change it or anything either.
