crezo
- Jun 19, 2009
It doesn't work. No way. And it will not work until the manufacturer fixes this problem. It's more complicated than it sounds.Hi
1. Update to FW 1.0
2. Go to Settings - Apps - Google Play services (GPS).
3. Press "Clear Cashe" button.
4. Press "Uninstall Updates" - it avoid pop-up messages from GPS.
5. Go to Settings - Security - Unknown sources.
6. Slide "Allow installation of apps from unknown sources" to ON position.
Now you can download and install apk files, all you need.
Enjoy
Не стоит. По крайней мере не в качестве основного устройства.So what is thoughts about this model ? Does it worth to buy it?
