Synthax
- Jan 11, 2013
Does BHA-1 use negative/global feedback in its circuit?
http://bryston.com/pages/warranty.html
Is there 5 or 20 years of warranty for the BHA-1 ?
James, Mike from Bryston please answer one question:
Why did you design the BHA1 not fully balanced? I have a balanced input with V800 DAC but from my understanding every input of the BHA1 is converted to Single Ended. So a balanced input has no benefit. Make this sense? Thanks
I know I'm not James, but the balanced input stage rejects Common Mode noise.
That's what it is supposed to do.
I'm not James either but also from far as I can tell the amp has discrete +, - , and ground from input to output.
It strikes as odd that an amplifier that accepts Single Ended and Balanced inputs, can drive either Single Ended or Balanced headphones, and has a differential (balanced) input stage to reject common mode noise from balanced transmission lines is perceived as flawed?
Wah?
I would like an official answer from James and Mike. I think converting from Balanced to Single Ended is not a good idea.
