NEW Chord Electronics Hugo USB DAC headphone amp for PSD and DSD Audio - Portable and Desktop, Now taking preorders - $2395
Jan 10, 2014 at 3:24 PM Thread Starter Post #1 of 5
NEW Chord Hugo USB DAC/headphone amp for PCM/DSD audio
Will Be Arriving Sometime Early February
Now Taking Preorders ...$2395
Chord Electronics Hugo DAC headphone amp
NEW Hugo reference grade DAC/headphone amp based on the same FPGA DAC technology that has helped establish Chord Electronics as an authority in digital audio.
Called Hugo (because you can take Hugo wherever ‘you-go’), the new device offers studio-master-tape sound quality, advanced connectivity and uncompromising file playback capability, all from a palm-sized player. Hugo is the world’s most advanced headphone amp/DAC, offering five digital inputs including A2DP aptX Bluetooth, plus advanced 384kHz PCM and DSD 128 playback for today’s high-resolution DXD (Digital eXtreme Definition) music files.
The new Hugo, which can be used as both a portable headphone amp/DAC as well as a reference-level source component in a static system, brings the renowned digital audio expertise of Rob Watts and Chord Electronics to serious headphone listening, enabling consumers to experience a world of super-high-resolution music via their headphones. It offers unsurpassed performance and technology and is unrivaled in the marketplace, thanks to its bespoke technology, FPGA circuitry and advanced file-playback capability.
Description
Hugo is ready to take advantage of today’s advanced studio-master-quality (DXD) music files. It can decode sample rates ranging from 44.1kHz to 384kHz (PCM), allowing audiophiles to experience music in true high definition, along with the best possible reproduction of CD-quality music. Hugo also benefits from two advanced USB inputs: one driverless input for legacy USB devices and one asynchronous high- definition USB port for operation up to 384kHz. Thanks to two additional digital inputs, coaxial and optical, any connected component with a digital output will also benefit from Hugo’s advanced technology.
Building on the strengths on the (two-years’-running) What Hi-Fi? Sound and Vision ‘Best DAC’ QuteHD, the new Hugo also has A2DP Bluetooth capability and uses a custom-made module with the aptX codec to feed a digital signal directly into the DAC circuitry, so even without cables, high-quality music can still be enjoyed.
In addition to 384kHz PCM files, the Hugo can also process DSD 128 data using the latest DSD-over-PCM standard (DoP). Whether using Mac OS or Windows OS, Chord Electronics’ own proprietary driver software is provided, removing the restrictions of current operating system audio playback.
Hugo has a built-in battery-charging circuit, with a full charge reached in approximately two hours. Hugo takes no power over its USB input (as this is severely limited with many partnering products) and only takes signal data, therefore, it is fully compatible with all iPhone, iPad and Android devices. Further features include an advanced reference-grade digital volume control that does not lose bits.
Like all Chord Electronics products, Hugo is built to last. The casework is precision- machined from aircraft-grade aluminium, with a bright silver hard-anodised finish (note: spotlight image shows titanium-finish prototype). Complementing the design is a top-mounted ‘porthole’ that gives users an intriguing insight into the internal circuitry, which changes colour with differing incoming sample rates.
Hugo is based upon Rob Watts’ and Chord Electronics’ famous bespoke DAC technologies and is the latest edition to Chord Electronics’ beautiful high-performance product range.
Specifications
Inputs
• Optical TOSLink 24-bit/192kHz-capable
• RCA coaxial input 24-bit/384kHz-capable
• Driverless USB input 16-bit/48kHz-capable (designed for tablets/phones)
• HD USB input 32-bit/384KHz and DSD128-capable (for computer/laptop playback; requires driver installation on Windows, others TBC)
Outputs
• 2x3.5mm headphone jacks
• 1x6.35mm (1/4 inch) headphone jack
• 1x (pair) stereo RCA phono output
Technical specs
• Advanced digital volume control
• Crossfeed filter network
• Battery powered for approximately 14 hours operation
• Input, sample rate and volume level indication by colour-change LEDs
• 26K tap-length filter (more than double when compared to the QuteHD DAC)
• THD: 140dB
• Headphone output: 110dB SPL into a 300ohm headphone load
Thank You.​
Drew Baird
Moon Audio​
https://www.facebook.com/MoonAudio/ https://twitter.com/MoonAudio https://instagram.com/moonaudio https://www.moon-audio.com/ https://www.youtube.com/@moon-audio sales@moon-audio.com
Jan 26, 2014 at 4:42 PM Post #2 of 5
Looking forward to some sound impressions.
I didn't realize Moon Audio was in Cary, NC. Used to work Cary Audio when Dennis was there. I designed the isolation bases for the amps and my proprietary isolation technique. That was back in the 1990's.
Apr 24, 2014 at 9:39 AM Post #3 of 5
Get Your Chord Hugo DAC Headphone Amp Today!
$2,395.00
FREE 2nd Day U.S. Shipping!
Chord Electronics Hugo DAC headphone amp​
Thank You.​
Drew Baird
Moon Audio ​
140 Iowa Lane​
Suite 204​
Cary, NC 27511
919-649-5018
Drew@moon-audio.com
Follow us Today!​
Jun 4, 2014 at 10:42 AM Post #4 of 5
NOW $2,345.00
Chord Hugo USB DAC & Headphone Amp for PCM/DSD Audio
Chord Hugo USB DAC & Headphone Amp for PCM/DSD Audio​
Thank You.​
Drew Baird
Moon Audio ​
140 Iowa Lane​
Suite 204​
Cary, NC 27511
919-649-5018
Drew@moon-audio.com
Follow us Today!​
Jun 16, 2014 at 10:04 AM Post #5 of 5
NEW Silver Dragon Toslink Form Fit Digital Cable for your Chord Hugo!
Starting at $100.00
Easily Connect your Chord Hugo to Astell & Kern's AK100, 120, or 240!
Starting at $100.00 Silver Dragon Toslink Form Fit Digital Cable
This is Moon Audio's Silver Dragon Form Fit Digital Toslink Cable.  We have made this Form Fit version in order to make it fit specific portable audio components with a smaller footprint.
The Silver Dragon Toslink has the band width to deliver upto 24bit 192k resolution as well as DSD signals.
The Silver Dragon Digital Toslink Cable includes: Gold Plated metal ends, metal ferrule protects fiber (it's not plastic like all the others) and its Fiber covered with 2 outer jackets (this is to prevent kinking).
2 versions are available for your preferences.  A standard version and a Mini Toslink version for use with such products as Apple computers with Mini Toslink Digital outputs.
Features
Gold Plated metal ends, metal ferrule protects fiber (not plastic like all the others)
Fiber covered with 2 outer jackets (to prevent kinking.
Finest plastic fiber available. utilizing 1300 core optical fiber.
Metal Backshell.
Highly polished ends.
Extremely flexible with bend radius of 17mm or greater.
Connection loss <.05dB.
Applications include : Dolby Digital (Dolby 5.1, 6.1, AC3,Prologic, etc.); DTS surround sound receivers; DVD players; CD players; Minidisk players and recorders;
MP3 and DAT recorders; Professional Audio Cards for computer digital audio workstations outboard; AD/DA converters; Satellite dish receivers;
Compatible with S/PDIF, ADAT, DAW, Dolby Digital, DTS devices using the Toslink interface.
