Feilong4
Does anyone know the diameter of the ESW11LTD earpads?
Diameter of the seat 75 mm
Диаметр посадочного места - 75 мм. Подходят от esw9, esw10. Но родные (кожаные лучше).
Или заказывать изготовление. Моя рекомендация - они должны быть не выше 10мм.
I'm afraid to misunderstand you. Better make a photo or drawing.Thanks! Do you know the size of the baffle/the part that holds onto the earcup?
This distance can be anything to your taste. Https://www.dropbox.com/s/te35p8zhbf6qmdw/_DSC1239.JPG?dl=0
But I did not like the products with a height of more than 10mm in sound.
Это расстояние может быть любым, на ваш вкус. https://www.dropbox.com/s/te35p8zhbf6qmdw/_DSC1239.JPG?dl=0
Но мне изделия высотой более 10мм не понравились по звучанию.
Thank you for your response, but I mean the part where I circled in the following picture:
I'd like to know how far it is able to stretch out, like in the following picture:
[/ QUOTE]
There's nothing to stretch. Its height is equal to the height of the landing ring + 2 of the height of the material from which they are made.
