Originally Posted by tangent
Sorry, but I don't buy it.
Well tangent, I didn't make this up. This came to light when an M³ builder kept blowing his LM317 on his STEPS at power-up (and his M³ was populated with the usual ~3000µF total of capacitance). His power switch was between the STEPS output and the M³ pcb. So, the LM317 was already powered up at full voltage when the switch was closed.
I asked him to do an experiment, with the power switch kept in the "on" position, unplug the AC cord and let the amp turn off completely. Then plug the cord back in. This is equivalent to having the power switch inline with the AC mains. The result of this experiment was that that the LM317 was fine and everything powered up ok.
The only explanation I could offer is that the fully-discharged capacitor bank on the M³ looks like a dead short for a small moment after the switch is turned on. Thus the transient charge current is very high. Since the LM317 is already at full voltage, despite the current limiting the it still croaked.
Contrast that to the experimental scenario. In this case the LM317 is powered up after the switch is closed, and comes up more slowly due to the transformer impedance and charge-up time of the rectifier caps. Also, the "ripple reduction" cap from the LM317's adj pin to ground also provides a soft-start function. The result is that the regulator's output voltage rises more gradually, and the transient charge current is dramatically reduced.
Since the builder still preferred to have a switch between the STEPS and the amp, I advised him to use a LM338T regulator which are rated at 5A instead of 1.5A, and that resolved the problem completely.
The National LM138/338 datasheet has an interesting paragraph that's relevant:
"A unique feature of the LM138 family is time-dependent current limiting. The current limit circuitry allows peak currents of up to 12A to be drawn from the regulator for short periods of time. This allows the LM138 to be used with heavy transient loads and speeds start-up under full-load conditions. Under sustained loading conditions, the current limit decreases to a safe value protecting the regulator. Also included on the chip are thermal overload protection and safe area protection for the power transistor."
The National LM117/317 datasheet mentions current limit protection, thermal overload protection and SOA protection, but has no similar verbage as the above. I don't think it is quite as advanced as the one implemented in the LM338. I doubt that the current-limiting is capable of protecting the regulator if the output is suddently subjected to a short circuit.
