erdinc
formerly known as marcelproust
- May 8, 2005
Hi,
I need passive noise reducing headphones that are comfortable for long time use and sound good. I'll be wearing them in front of my computer for general use. I'm currently using Sennheiser HD595's and I like them a lot. The problem is there is too much outside noise and I need closed headphones.
For me the important criteria is as follows in that particular order:
1. It needs to block outside noise fairly good. TV or music noise coming from neighbours, children running upstairs, people talking in the next room etc. should be blocked, if not completely at least fairly good.
2. The second criteria is comfort. Sometimes I use my headphones for 12 hours or even longer during the day. I guess it will be hard to beat the comfort of HD595's, but at least something close to them, something that I can wear for a few hours continuously every day would be nice.
3. The third criteria is sound quality. I quite like the liveliness of my HD595's. I also own the HD650's but I prefer the HD595's. I don't want too bassy headphones. But sound quality comes after isolation and comfort. I'm not going to use these headphones for critical music listening but it would be nice if they don't sound too bad.
The headphones will be directly plugged to an Emu 0404 USB and I'm not planning to buy a headphone amp. any time soon.
Please don't suggest IEM's. They are not suitable for the way I want to use headphones. I want something that I can put on for a few hours and leave them on even when I'm not listening to something. The IEM's create a sense of awareness and underwater feeling that bothers me more when I don't listen to something. I only wear IEM's when I'm on a plane or public transport.
My budget is up to £150. The AKG K271 and Beyerdynamic DT770 PRO are within my budget but I don't know how good they isolate noise or how comfortable they are.
It could be also a headset (with microphone) if you know something that has good passive noise reduction and is comfortable.
Thank you
Erdinc
Thank you
Erdinc
