Originally Posted by runeight /img/forum/go_quote.gif
We can use electro-mechanical devices (such as the e12) to help with this. But even here, if the transient is fast enough the offset detector may not have enough speed. IIRC the e12 operates on the 10's of mV scale electrically and that further delayed by how long it takes the relay to flip the contacts once the voltage is applied. Other offset detectors have to work on similar principles because if they are too fast they will trip from ordinary audio signals. So the integration time constant has to be long enough for the DC offset to really be of significance but short enough to actually protect the headphones. This works very well for "slow" transients.
NOTE! this is all my own "gut" instinct and should be checked up on if you want really concrete info... If anyone does more research on this, I would happily be proven wrong (or better right!) to better the community.
I dont think that the transient is the problem, even the spike up to high voltages and instantaneous currents higher than what the size of the voice coil wire would suggest. At some point, I agree, the current from the offset will burn through the actual voice-coil wire basically instantly, but I think in real-world failures it will take longer than most people expect. There have been several threads throughout the ages where people have "observed" heat coming off of a driver that was exposed to DC. The drivers later produce "some" sound, and impedance measures OK, but the sound is clearly off.
I am (personally) more concerned with long-term exposure to even lower DC offset and the fact that it will eventually melt the plastic or glue that holds everything together, OR soften the plastic of the "cone" and then it can warp (see more below). At lower offset levels, this will take more time AND voltage offset than it takes the e22 to trip so you are well protected. It is possible that the offset is so bad, and the current so high that the voice coil basically burns up instantly, but even in the 32V/1A into a grado example, you may still be OK (I dont really know) while you wait for the e22 to trip. Your amp is TOAST even if the headphones are ok...
However, let's make up a hypothetical case for discussion. Suppose a 32V transient is applied to 32R headphones. At full voltage the headphones will be sustaining 1A. There is a rise time and fall time. How long can this transient last before the coils are damaged? 1us? 10us? 1ms? Etc. This number is different from the amount of continous current that a particular wire gauge can pass (although those number are extremely helpful). |
As another point, the 32V offset would only happen if a transistor *suddenly* failed in a DC coupled amp which is possible but rare. Historically, the damage is done by a low-voltage long term problem. part drift in an amp with no DC servo, servo lag-time (EG: an amp whose DC servo dosnt "kick in" for about 20-30 seconds) or an amp that drifts beyond what the DC servo can accommodate due to over-heating or some other part-drift. thermal-run-away anyone? In these cases, the offset may be a few-hundred mV which can destroy a headphone if its allowed to remain for more than a few moments, but if removed quickly should pose no long term harm to the headphone.
Edit: Another aspect of this is damage to the diaphragm. If the current is really high it will pull the diaphagm very hard in one direction. When is the diaphragm permanently warped by this? If ever? |
You can wrinkle some drivers with excessive SPL, but most simply bounce back to their original form. It is possible to "heat" them just enough to warp them with long-term mild DC offset though.
