Need help! really confused with amp/dac choice for dt990 250 ohm pro
Feb 27, 2017 at 11:37 PM Post #31 of 38
hihi i [COLOR=212121]was tempted by the price and when I get a job, I plan to build a gaming pc, that's where i spend lot of money to buy good amp and the others for gaming. that's what I think right now.[/COLOR]
[COLOR=212121]ok i will think it again wheter to buy 250 or 600 ohm version. i will wait 1-2 month, if i got a job, i will buy 600 version but if not, i will buy 250+e17k instead.[/COLOR]
[COLOR=212121]if i buy the 250 ohm version, which one do you advice, pro or premium 250 ohm?[/COLOR]
There is no difference in sound quality between pro and premium version. Only the build materials. Just choose whichever one looks best to you.
Sep 27, 2017 at 11:43 AM Post #33 of 38
schiit fulla 2:
Potenza massima, 16 Ohm: 550mW RMS per canale
Potenza massima, 32 ohm: 360mW RMS per canale
Potenza massima, 50 ohm: 230mW RMS per canale
Potenza massima, 300 ohm: 40mW RMS per canale
THD: <0,003%, 20Hz-20KHz, un RMS da 1V
IMD: <0,002%, CCIR
SNR: > 105db, A-ponderato, riferito a 1V RMS
Crosstalk: > -75dB, 20Hz-20KHz
Impedenza di uscita: 0,5 ohm
Guadagno: 1,7 (4,6db)
vorrei prendere dt990 pro beyer, o hd598 sennheiser, su schiit fulla 2, cosa ne pensi? grazie. Translate by google.
Sep 27, 2017 at 11:48 AM Post #34 of 38
Soooooo... I looked all over and I'm getting various opinions which make me more and more confused.
The amps/dacs I am looking to buy to help power the dt990 250 ohm pro's is the fiio e10k. I currently have a xonar dg sound card in my pc that I don't mind bypassing because I don't use the dolby headphones on it really at all. I initially put it in there as a small upgrade from on-board sound when I build my pc. As for the fiio e10k some people are saying they are not good to power the headphones and other say they work beautifully. So I am just a little confused.
My question basically is: Does the fiio e10k power the Beyer DT990 250 ohm pro headphones and the reach a reasonable volume while still sounding great? OORRRR... Should I just get an amp and use my xonar dg as my source/dac? and what amp would be a good suggestion? budget ~130ish.
Thanks for any help you give to this audio noob!
Magni 3 hands down. Best amp for 100 bucks period. E10k isn't good for high impedance and Magni 3 is only 30 bucks more at most and destroys it in every way other than size
Sep 27, 2017 at 2:16 PM Post #36 of 38
