breuer
- Sep 8, 2012
Two years ago i bought a pair of etymotic hf5 headphones, i'm no sound expert but i found their sound clear and enjoyable although a bit too soft on the bass department.
In the last few months signs of wear began to appear on the headphones, my dad replaced the connector which fixed the problem for a while but now i'm looking for a long term solution.
Should i re-cable the headphones or simply buy a new pair?
I have a recommendation for a guy who does the re-cabling for about 40$, my budget for new headphones is 80-100$ and i listen mostly to pop, rock. hip hop and other mainstream sounds.
I would like to hear you're thoughts about my decision.
