Ok, just got out from the operation theatre..
Opened up the SRM-717 with the ellen key, got a friend who's train in electronics and a qualified electrician to help me out.
The unit was configured for 100v. Tried to remove the top green plate, and it's glued with 3 round rubber knobs to access the PCB for the transformer. Didn't want to break anything, we unscrewed the 2 screws that holds the PCB to the chassis...now that's the tricky part, and luckily the wires are LONG enough for us to slowly pull the PCB out.
Metal jumpers were set at position 1, 3 & 6. Moved jumper 6 to position 5, removed jumper 1. (Thanks to spritzer and audiod for sharing).
Placed the PCB back, did some probes with the multi-meter... professional hazard, my friend left no stones unturned tested everything to make sure that there's no shortcircult anywhere (even the screws were not spared).
And moment of truth, plugged it into the 220v main and the power LED lights up, the red LEDs in the 717 lights up beautifully...and most importantly, no kabooms
Now can't wait for the O2 to arrive to test run the unit!
