stuartr
Loyal member of Team Useful Post.
- Oct 18, 2001
Eric -- keep up the good work. Photography is a really rewarding hobby -- I wish I got into it in earnest at your age. Though I did not really embrace photography as a kid, my dad was an amateur (but very good) photographer taught me about different types of light, color, the rule of thirds and composition as a kid, and I really think it changed the way I looked at the world -- if not more artistically, then more aesthetically. He did not really talk about this from the perspective of a photographer, just as an observer of the environment. I think I really benefited from that different perspective.
It's much easier to make a sharp lens with a slow aperature. In any case, most well-made primes will be much better lenses than zooms -- it is a simple matter of physics -- they generally have far fewer elements. The light is traveling through less glass, so there is less room for aberrations and loss. I have a leica rig, and I use the 50 mm f/2 summicron, many consider it the sharpest consumer lens made -- I think it is also the second cheapest leica lens and the second slowest 50mm. it is certainly noticeably sharper compared to any of my other lenses. Slides just look more 3 dimensional and colors are more...well, real. I think voigtlander made a 3.5 heliar special edition awhile back that was supposed to be even sharper...However, there is definitely something to be said for super fast lenses. I think my favorite lens might be the Canon FD 85 mm f/1.2L...you can completely isolate out your subject, shoot by the light of a candle, and since it is a floating element design, its performance wide open is as good as it is stopped down. I think I will add digital to my arsenal when full frame sensors in the 10 megapixel range are available in a compact leica M mount and are more or less economical. I think it will be about 5 years. Until then the focal length multiplication factors and the gargantuan size of modern pro DSLR's is just too daunting. Excuse my curmudgeon-ness. It's just that I find people shy away from me when I point my admittedly intimidating Canon T90 with 85 mm lens (it is a 72 mm filter size with a large hood), and the T90 is still half the size of the D1s, EOS 1V or the D1X, D2H etc...those things are bigger than a hasselblad!
Originally posted by ipodstudio It's funny: Nikon have the almost identical AF 50mm f1.8, which is also dirt cheap (about $70 as well) and is tack sharp. Most Nikon pros I know keep one in their bag and many prefer it over the 4 times as expensive AF 50 f1.4...go figure... |
