UntilThen
- Jun 16, 2015
M51 is a no brainer at the price now. It's my 2nd dac next to Yggdrasil.
Are you running the M51 at 0dB? If so try reducing the output to -3dB or -6dB.Could someone clever advise why the 2go/2yu doesn't play nicely with a NAD M51 dac? Sound is muffled and scratchy through USB and through coax. Both units work fine in other scenarios so I dont think anything is faulty.
This solution solved the issue. Many thanks.Are you running the M51 at 0dB? If so try reducing the output to -3dB or -6dB.
Glad i could helpThis solution solved the issue. Many thanks.
While you're at it, check the polarity setting, in my case i get slightly more bass impact with the reverse setting selected.This solution solved the issue. Many thanks.
Great, thank you very much jeenam.I will be able to try the versions 1.41 and 1.39.
