SHAMuuu
- Sep 23, 2013
Wah wah wee wah that is a Nice headphones
Will this come with piggytail to speaker tap wire?
The novum: Single sided connected to the earphone even in the case of symmetric connection.
Could we have 2 long cables instead please? I don't think a short cable is necessary here
Sorry, I didn't get it. Do you mean that you can connect the cable either to the right or the left side (like some Dj headphones)? By the way, the connector on the headphones is a 3.5mm jack?
I would not be so sure. The Mysphere is going to be quite sensitive, so people will be able to use it with portable devices. And now many people prefer to use their headphones with something like the Mojo or AK380, instead of big home amps and dacs.
Any chance to have earpads compatible?
Like a round molding around that a ear parts so a pad from Brainwavz or ZMF can just wrap around the headphones?
Hello,
Sorry, may be I described it not clear enough.
> The cable can be connected either on the left or the right side of the headphone bow.
> The internal wiring is completely symmetric designed. This is valid for the internal wire length as well.
> When connecting a cable with unsymmetrical source - it will work as well.
> The used connector at the moment is a 4-pole 3,5mm jack on the headphone side. However, we're still searching for a clever alternative. It's about small size, and low mass as well.... Any good idea are welcome when passed by a PM to me.
> Yes, Mysphere 3.1 will be quite sensitive and usable for small and not so powerful amps. This is why devices as AK380 would fit perfect. But such devices offer not in all cases symmetric amps. This is why we will offer both connection types for the cables..
> However, the cable will be an option which shall be selected during the purchasing process. Of course more than one cable variant will also possible to select.
BR heinz
I am soooo eager to listen to the prototype this Saturday! I'll reserve a special table for you, Heinz
Thank you !
We will not need much space, but a relative quiet area would be helpful, as Mysphere 3.1 is acoustically totally open.
As amp I will come with Lake People HPA RS 02/08.
For comparison I bring Focal Utopia, Sennheiser HD800s and AKG K1000 Prototype as well.
As music source I do have only my notebook. But I'm sure many other will have their own sound source with them. As Mysphere 3.1 is quite sensitive, there is no problem for any amp.
BR heinz
Will you able to share impressions of your experience on the forum, or is that prohibited given that it's not the final production version?
