scorpian007
- Jan 5, 2005
Hi,
Just running my own battery tests on the Zen Micro and I thought I'd share my initial results on my first test. More tests are to come and will be posted as I get time to do them (maybe after exams are over
). I've also posted this on the Creative forums.
TEST 1:
Battery was fully charged before running each test. Backlight was turned off, EQ was off, SVM was off, player was set to repeat all, volume level at 22. Player was playing continuously throughout this test with no interruption to the player at all. I've had my Zen Micro since the end of January and am using the battery that came with it.
Firmware: 1.10.02
Album: Camel - Rajaz
Bitrate: 128Kbit CBR
File Format: MP3
Time at 3 bars: 00:00:00
Time at 2 bars: 02:28:51
Time at 1 bars: 06:04:31
Time at 0 bars: 10:41:05
Time at low battery indicator: 12:30:25
After the first bar dropped off at 2:28:51, I didn't think the player would last more than 10 hours, but surprisingly the time at 2 bars and 1 bar was very long and it ended up playing much longer than I expected! (It was about 1-2am when the player completely stopped, I was so tired
). So looks like Creatives claims aren't dodgy at all when you have the same options set as I did.
I changed the firmware back to the original 1.02.05 because of the battery drain anomaly when in sleep mode with the firmware version 1.10.02. I haven't performed my second test yet but I'll be using the same settings as test ones with changed in these variables:
Test 2 (yet to be completed):
Firmware: 1.02.05
Album: Opeth - Damnation
Bitrate: 192Kbit CBR
File Format: MP3
Time at 2 bars: 00:00:00
Time at 1 bars: 00:00:00
Time at 0 bars: 00:00:00
Time at low battery indicator: 00:00:00
I'll keep you guys posted!
TEST 1:
Firmware: 1.10.02
File Format: MP3
Firmware: 1.02.05
File Format: MP3
