Phredd
- Aug 23, 2005
I bought the Sennheiser HD700 and I wasn't completely happy with it, though I was listening to it through the headphone jack of my receiver with unknown specs or quality. Based on reviews I decided to try the Grado RS1i. I like it a lot. Today I received the JDS Labs C5D and now the HD700 sounds much better, so the decision just got more difficult. I can't afford to keep both and they both sound so different.
I don't know if I would describe the RS1i as clear and true compared to the HD700 as a little colored. Or that the HD700 is more full sounding and warm and that the RS1i is a little harsh. There's definitely deeper bass on the HD700. I've been going back and forth between the two, replaying the same music. It would be easier if they were similar to choose which is better. Maybe I should just listen to each for a few hours instead of going back and forth.
A couple positives for the RS1 are that it's a little more comfortable being on the ear and that it's 32 ohms so I could play it from my iPhone without the amp. But my first priority is sound quality. I have other headphones for portable use. (MOE, HD598 and Westone W40) Besides, the C5D is a portable amp.
Also, I was a little disappointed in the condition in which I received the RS1i, with nicks and a crimped cable. I sent photos to Rich Grado and he said that's just what a hand-made product is like. Is this what the rest of you Grado owners are used to? I'd appreciate suggestions from owners of the RS1i or the HD700, and especially those who own both.
