PurpleAngel
So if I didn't get a sound card and just got an amp, say an O2, and plugged it into the the back of my motherboard it wouldn't sound as good as just plugging my headphones straight into the sound card?
Also I'm confused why people say sound cards make the sound better after watching this video: https://m.youtube.com/watch?v=d1rXcJuEsy0
The O2 (Objective 2) amplifier is better then the amp built into the SB-Z card or E10K.
So using it to drive headphones is a good choice.
Getting an Asus Xonar DX (used, $60) and using it with a O2 ($130) would make a great combo.
There is also the Schiit Magni ($100) amp and FiiO E11K ($60) amp
With only buy an amp, your still using the motherboard's DAC (Digital to Analog Converter), which is usually not as good as the DAC function built into the SB-Z or E10K.
Also the motherboard's built in audio processor may not have as good headphone surround sound.
Motherboard's in the $150 and up range start having fairly decent built in audio (Realtek ALC1150)
Chances are $250-$300 motherboard's built in audio would be about equal (or even the same hardware) to a Sound Blaster Z sound card ($60).
The guys over at Tek Syndicate explain computer audio a little differently then I would, or other Head-Fiers.
Every year motherboard on-board (built in) audio hardware in general gets better, can't argue there.
Also each motherboard manufacturer decides how much they will spend for built in audio hardware.
There are little extra's that can or might not be used for the audio hardware, which can effect audio quality, depending on who made it.
Each time a motherboard design is revised by the manufacturer, the audio hardware used can change, for better or worse (assuming it's usually better)
