ljokerl
Portables Reviewerus Prolificus
- Mar 2, 2009
Yes, that's right. I was just using X10s as the plural of X10.
Brainwavz B2 | 9.2 | $130 | |||||||
VSonic VC1000 | 9.2 | $125 | |||||||
VSonic GR07 Bass Edition | 9.1 | $129 | |||||||
Rock-It Sounds R-50 / R-50M | 1 | 9.1 | $120 | ||||||
HiFiMan RE-400 Waterline | 9 | $99 |
Wow Joker, this is a spectacular effort. And the result is just mind boggling. Thank you for putting the time into this. It has really made it easier for novice audiophiles like myself to join the group and really enjoy some quality headphones =) My last purchase (VSonic GR06) was heavily influenced by your research. I'm now looking to upgrade again =)
I'm an avid trance fan that loves his bass and is looking to spend max $150. To and from university and at the gym. When entering the price range into your table and arranging by sound quality, I get the list below.
Brainwavz B2 9.2 $130 VSonic VC1000 9.2 $125 VSonic GR07 Bass Edition 9.1 $129 Rock-It Sounds R-50 / R-50M 1 9.1 $120 HiFiMan RE-400 Waterline 9 $99
Given my music tastes, would you recommend any of these (or maybe some not on the list) above the others? I have also read many good things about Yamaha EPH-100 but they are rated a little bit lower on your list. Really appreciate your help! Stefan
Great sound doesn't mean much if it's not the sound signature you are looking for. Preference definitely trumps performance at this level.
Great sound doesn't mean much if it's not the sound signature you are looking for. Preference definitely trumps performance at this level. ZapX629 is right - out of those, the GR07 BE is the only one that can be suitable for a bass fan, and even that barely trumps the GR06 when it comes to bass quantity. The EPH-100 is a different story - it's a great earphone for bass - very extended and powerful, but not lacking in other areas. I really like them for EDM and it seems like it would be more the right choice for you.
Yea that's what I've been struggling with, this idea of sound quality vs. sound signature. How does one even objectively define sound quality? Overall balance? Does the fact that I love bass, by definition, mean that I prefer earphones that are less balanced?
Thank you very much, guys (especially to Joker)! I'll try to find X10 and pray it will fit to her ears properly.
Thanks Joker, that was promising to hear!
I am very convinced with the sound signature and the looks of my AM800's. Best looking wooden IEM, by far!
After having the FXT90 for almost a year, I gotta admit I love these and agree with its "engaging" sound. My ears prefer FXT90 more and more to the Yamaha's EPH-100 whenever I play some rock / metal but I wish the FXT90 could have bit more rumble and boominess of the EPH-100.
Furthermore, I'm impressed that FXT90 is few of earphones I have that is good on its own stock tips. I tried fitting it with Sony's MH1C tips and it sounded more livelier (and better in my opinion), like guitarists amping their guitars toward maximum volume. But, I ended up going back to the stocks because it fatigues quickly.
Although I have no problem with its lack of deep-bass and rumble (or boominess), I've been wondering what is mid-bassy? As in mid-bass hump that you described in your review.
Xears xe200pro?
L-shaped and sq is behind the ttpod T1E. But its wooden...
I also bought astrotec AM800 based on the review here but i found them lacking in bass.
1. The sound is clear and very bright as described but there is no deep bass to be felt or hear at all.
2.They sound is very loud on my smartphone -- on the past i have tried some Sony 16 ohm 100db + also the famous MH1 and the volume was really low, especially the mh1.
3.My brother bought some cheap oem headphones from e bay for 5$ and while the are lacking clarity , the quantity of the bass surprised me , and the music was still very enjoyable.Loud too!
4.So what i am looking are easy to drive headphones for my smartphone (16 ohm?) (105db and up?) ,sound like the astrotec but with way more bass...The JVC HA-FX1-3 are they good for that? Also thinking about the Denon AH-C300 ...
