Multi-IEM Review - 352 IEMs compared (Pump Audio Earphones added 04/03/16 p. 1106)
Nov 29, 2012 at 7:28 PM Post #8,882 of 16,931
Very nice review of the R-50 and I figured you'd give it a 9.2 like most of the other TWFK.  Now a lot more people will buy them because my words don't carry the weight yours does.
Nov 29, 2012 at 9:13 PM Post #8,883 of 16,931
Thanks for your answer and reviews joker.
I've got one final question.
If the only shortcomings one finds on the gr07 is sibilance and want of more subbass quantity, what would be your recommendation?
Does the eph-100 suffice? Or are there better options?
Nov 29, 2012 at 9:42 PM Post #8,884 of 16,931
@ljokerl
First of all, thanks for your R-50 review!
Unfortunately, you should update your DBA-02 mkII review because the price is now $198.90 plus $10 shipping: http://www.musicaacoustics.com/wp/headphones/fischer-audio-dba-02-mkii/
Oh wow, that's a bit of a hike. I'll have to update the price with the next edit. Doesn't look like the $10 shipping is mandatory, though:
All Musica Acoustics product prices include shipping. However, if you would prefer Express Mail Service (EMS), choose it from the pull down menu. EMS is trackable, signatory, and delivers almost anywhere within five business days. Its cost is $10.00 on top of your purchase.
Meelectronics A-161 is a good choice? I prefer classical music..
Should work very well unless you require a large/out-of-the-head soundstage.
Thanks
. I feel like I could happily use them as my main earphones with the tiny bit of tweaking I've done.
Maybe one of the two new versions of the GR07? There's an MKII and a Bass Edition. I've heard neither but supposedly they are tuned in the direction you want to go.
The EPH-100 has the right tuning but it just isn't quite as clean-sounding as the GR07. Otherwise it's as good a choice as any.
Nov 29, 2012 at 10:50 PM Post #8,886 of 16,931
Excellent. I love the R-50 review. Makes me want to go for it.
That proves my point about since Joker rated them high more people are going to get them even though I've been telling people the same thing for months.
Nov 30, 2012 at 12:00 AM Post #8,888 of 16,931
I think the same thing happens to the BA200 lol
Nov 30, 2012 at 3:09 AM Post #8,889 of 16,931
Yeah, I'm glad that I got them from your suggestions..Was looking @ R-50,GR07 , EPH-100 and TF10, hopped up on TF10 and R-50 from your suggestions ..I should get a BA-200 soon :D
I'm liking my MH1C a bit more than R-50 for my musical preferences, could BA-200 an upgrade on this or which one do you suggest? or eQ-5? Whats your opinion too |joker|?
Nov 30, 2012 at 6:31 AM Post #8,890 of 16,931
Sorry for the insistence. Here in Portugal, the choice is reduced. I listen to mostly classical music and rock. My hypotheses are:
Astrotec AM-90 .. £ 34
I3C-S Dunu .......... £ 50
Creative Auvarna In Ear 2 .. £ 50
Head-Direct RE0 .. £ 55
Etymotic MC5 reserch .. £ 55
Meelectronic A161 ... £ 70
What is the best chance for me? (2 or 3 best)
The RE0 will need to amp since I have a Sansa Clip +?
Thank you
Nov 30, 2012 at 7:59 AM Post #8,891 of 16,931
Edit : Will post in its own thread
Nov 30, 2012 at 10:51 PM Post #8,894 of 16,931
killer thread! Grado GR10 someday!
 Thanks! Appreciate the reviews!
Great Review joker!I'm definitely craving me some R-50's now.
Thanks
I haven't heard the BA-200 and the e-Q5 is not an upgrade over the R-50 per se, just a smoother and mellower sound.
Thank you
Really don't know what sound signature you prefer. The AM-90 is a safe way to try balanced armature sound without breaking the bank. The I 3C-S is a good deal if it's cheaper even than the MC5. The RE0 or A161P would be jumping straight into the deep end as far as fairly neutral/accurate sound signatures go. The RE0 actually sounds quite good with the clip. The RE-ZERO is even better.
Dec 1, 2012 at 5:54 AM Post #8,895 of 16,931
Great review as always Joker! Man, you are unbelievable! After your R-50 review, I ordered my R-50s but I think I will need replacement tips for them. Which aftermarket tips work best for R-50? Should I choose Etymotic triple flanges or MEElectronics triple flanges? Which one is more comfortable and offers better sound?
