Anaxilus
- Mar 12, 2010
Read the whole article. It is describing the EX1000. The 7NOFC cable. Extra short cable accessory. The EX600 uses aluminum not magnesium according to Sony. Way off.
OK but I still have a hunch Sony mass-produced the LCP driver and are omitting it from the specs online and on the box to favour marketing for the EX1000, since reviews are saying they sound very similiar, and if the EX600 is using an ML polyethene driver like in the EX700 then it should not sound close to the EX1000 at all especially since the FR graphs are quite similiar and the EX700 already uses a magnesium inner-housing and sounds like crap according to most users! p.s. here is the LCP in the Z1000 driver http://assets.head-fi.org/7/74/1000x500px-LL-748eb9ac_2.jpg
Sorry joker for hyping the ex600 a bit in your thread, I realise there are dozens of great IEM's out there like the GR07 which costs less at $156 including shipping, and james444 has pointed out that it's more for "romantic" listening and er-4P/ck10 lovers might not rate the ex600 very highly..
You could go ahead and make some theories on it, but I trust Sonys' specs. If anything the Japanese companies are the most trustworthy when it comes to specs, JVC being another. Yes, EX600 sounds similar but like I said, they have similar tuning but the EX1000 is still a step ahead and it uses a different driver. The EX700 uses a unique bio-cellulose not a ML like the EX600. I think it's all pretty straightforward, no need to overcomplicate it.
You have to call them up. Annoyingly, they never respond to email or contact forms.
Edit: ok ok fine that article is just posting the ex1000 specs and I was misled/being optimistic hoping Sony put their best driver in the cheap ex600 :/ :/
I'm still confused how the EX600 can apparently sound so much better than the EX700 if they are both using the same ML polyethene type driver, and the EX700 even has magnesium inner-housing which should lean it more in favour of the EX1000, but the EX700 is harsh and has weak imaging, is it the shape of the housing? different filters? I cannot rest! Sorry.
I don't mean to hype the EX600 I realise there are other offerings out there like the cheaper and more snug GR07, and james444 has pointed out that it's a "romantic" IEM and CK10/ER-4P lovers might not rate it very highly.
hmm i live here in the UK, and i can only find international numbers?
I have once again another question! Joker. How would you compare the highs between the q-jays, visonic Gr07 and the FA dba02 (very similar to the Brainwavz B2?)?
It seems i wasnt very comfortable to the crispy highs of the q-jays. I likes the clarity and transparency but not very aggressive.
Monster probably handles warranty through their local retailers/distributors but I'd give them a call anyway.
I think I would stay away from all of those if you found the q-JAYS aggressive. Maybe a smoother dynamic like the RE252 or the slightly darker Westone 2 would be a better match.
hi. how is sound quality of vsonic GR07 compared with headphone audio M50? i like very much the sound of M50....GR07 have a sound like M50? or exist better options like FA dba02?
vsonic GR07 still is one of best preice/performance on market?
thanks
Joker what's your initial impressions of the Sony ex600/ ex1000? If ex1000 is on par with westone 4 I will buy me thinks.
The B2 and is smoother overall but it was still a bit too top prevalent for me.
