dstarr3
I have an Audio Technica A900x, which originally had a single fixed cable that was getting stiff and ratty, so I modded the headphone to have a 3.5mm connector at each cup so I could use them balanced or single-ended just by using a different cable.
After reassembling the headphone and giving it a listen, there's distinctly a lot less bass on the right side now compared to the left. What would contribute to a closed headphone cup losing bass? To make room for the 3.5mm connectors, I had to remove some plastic material from the cups, but I tried to seal everything back up by stuffing some Sugru around the connector and molding it into place so that there wasn't any new openness in the cup. Any material I removed, I basically just replaced with Sugru after fitting the connectors.
That all being said, the right side has less bass now than the left side. So what would contribute to that? Would loss of bass indicate that I sealed it too well or not well enough? Or might I have done something else wrong? I did technically rewire everything using wire recycled from the removed headphone cable, but I don't think a simple rewiring would cause specifically a bass drop, and only on one side.
Let me know your thoughts. Thanks in advance!
