Old Pa
- Dec 9, 2001
Yup, red is right all the time (if it isn't then somebody before you screwed up
). Another dumb point (which I find I have to be careful about): the two pin connectors to each Sennheiser phone side are of different diameters to maintain correct polarity. The difference is slight, but visible if you look for it. How much tightness in assembly is caused by trying to put the big pin in the little hole? Oops.
Originally posted by Juergen Here's a dumb question.... What side should the red dot connector go on (L or R)? I assumed red goes on right. |
