MikeW
- Nov 4, 2005
I recently built a Mini3, all the intial checks are fine except one.. The battery charging circuit, it only reads as 03.12ma for current. supposed to be 16ma. Voltage is fine @ 12.17 volts. I double checked the R8 resistor and it reads 74.6r. I double checked polarity of C2 seems fine. Im at a loss, wonder if im reading it right, using my craftsman auto-ranging VM. set to ma/current readings. The rest of the amp seems to work great.
I also tested the current ma, output of my power adapter, a reiliapro 15v 500ma unit, the voltage was 21 volts, and current reading on my VM said 05.85ma. makes me wonder if im reading it wrong or not understanding the measurement. Maybe a decible point off? so it should be 585ma? i don't know. If that's the case though i'd be getting 31.2ma in my charging circuit, that's still way off the mark. This was a glass jar audio kit btw.
p.s the charge led does come on, and the battery does charge. but it takes forever.
