Loose-Leaf
Anyone using the ZMF ORI LE headphones that is recommended on LTA web site ?
Hi all , Pardon me if this has already been discussed ,..Who has tried the early 1950s Bendix Red Bank 2C50 / 12sn7 in their Microzotl ? I think they are the cheery on top ,.
I think I was getting ahead myself expecting something better by rolling tubes so soon of receiving my MZ2S ,I just got in a pair today and am letting them settle. They seem to have a lush mid-range with lots of good, tight bass but their top end has not reached the airiness of my 14N7s yet. I only have a couple of hours on them and as you might have noticed the MZ2 seems to take longer than other amps for tubes to break-in. These are very promising however.
There were simply too many things settling in at once , new components and new interconnects all going through various stages of change and now after weeks of listening I'm sure all has settled in .Currently I'm using LTAs selection of tubes also I did change out the chassis RCAs in the MZ2S with silver Eichmann which my interconnects are terimiated with also including replacing the standard ac cable from power supply to MZ2S to the premium cable offered on LTAs site . Right now I'm thrilled with what I'm hearing and perhaps someday try the Red Bank Bendix including some select 12AT7s and with that any changes would be easily decerned ,
Yes patience is a virtue and finally after a year my attempt at putting together an enjoyable headphone experience was renewed with the purchase of the ZMF ORI LE and MZ2 S .Sounds like a good plan. The MZ2 and Z10 are amazing pieces of kit but one must be aware that to get there takes a bit more break-in patience that with other equipment. Tube swapping break-in especially takes longer as does warm up with each listening session.
Our patience is rewarded by remarkable sound and long lived tube life as well.
Has anyone bought the newer unit with remote? I don't see pictures on their site of a remote. I am contemplating sending my original MZ2 in to upgrade to remote control (and the 3rd input). It sounds like they are just going to give me a new unit. I recently bought a Schiit Vidar and Saga combo, but I wasn't aware they added the IR sensor to the MZ2. I would imagine the MZ2 would destroy the Saga as a Pre-amp.
Hopefully someone can chime in with their experience with the remote functionality.
You've made me realize that in updating the site photography to make sure the newest version of everything was shown, I did not include any pictures of the remote. It is a standard Apple remote. Here is a photo of it with an MZ2 (which no longer has the white ring around the HP jack).
The Schiit preamps use a nice-quality digitally stepped attenuator - I actually use a Saga at home. Before committing to the upgrade, though I think it will slightly improve your unit beyond adding remote functionality, I'd suggest spending a few days laboriously getting up to change the volume and trying the MZ2 in your system as a preamp. I believe the Vidar employs a novel topology and every preamp does not find synergy with every power amp. Another option (which I'm currently trying in my home system) is to use the Saga in passive mode and insert the MZ2 in the chain between it and your power amp.
Sorry if this was already covered, but I would like to know if it is still possible to use 6SN7 Tubes in the S Version which comes with stock 12SN7 tubes.
