- Jan 29, 2010
Just try the tube out and see if you like it, it's only a replug.
Another option is switching the opamps as explained on page 1
Yea go ahead and try it, personally I don't think I hear a difference at all and this is using the switch on my amp with both SS/Tube Preout connected. There are some opamps out there that mimic the same kind of properties(distortion and oscillation) of a tube. Problem is one of these is an HDAM from audio-gd which distorts on the maverick.
If you hear a huge difference you can then start messing with the tubes.
Help ...
The Volume control bypass...I accidently (twice) push it in and it was very loud this happened late at night and I woke up the house. I'm going from Mac to D1 to amp to speakers. My Mac setting it's on mute so the bypass should be mute? instead it's on full blast. I was going to put the red tape on the bypass button that just seem strange. It this the way The D1 is design?
hi...
please help.
id like to know if this will help me achieve good sound quality from my ipod and active speakers audioengine a5 and subwoofer a8...
because, something is missing in my set-up:
ipod+apple dock+audioengine a5+audioengine subwoofer s8.
what does DAC do with my ipod?
does it make it sound more good?
sorry for my english.
Your question is answered in the FAQ on page 1:
The original TubeMagic was a Xiansheng DAC-01 clone but has since evolved into a more thoroughly researched and tested unit with several modifications and upgrades, not to mention a better looking case.
hi...
please help.
