Raidersfan8118
- Jan 29, 2016
Wonder if I can get some help from here. Sound will only play through my laptop speakers and not through my headphones.
Thanks I ended up getting it I had to set it to default on sound in control panel. Now I’m trying to get apo equalizer to work if you have any experience with that.I assume u have installed the relevant drivers and also changed the sound output from your laptop speakers to usb/matrix?
I had exactly the same it drive me mad ,changed my streamer to lumin mini and back to normal 24 bit 192 backSo I just got the X Sabre Pro with MQA and i cant seem to get it to sample above 24bit 44.1khz despite having tidal playing and it set to stream as Master settings. I made sure to update with the latest firmware as well. Am I doing something wrong or is there a setting I am missing?
