Syzygies
- Nov 16, 2004
My experience has been mixed with getting iPod line out to my CMoy amp, and I want to do better when I build my PIMETA. The particular SendStation PocketDock Line Out I bought sounded dreadful, with serious distortion. Who'd think you could botch the sound in such a short distance? They sent me a free replacement, which works fine.
I haven't tried the Sik DIN but I've been corresponding with them; they will come out within a month or two with a gold-plated male version. Meanwhile, I've stuck an Apple Dock to the lid of my Altoids tin, my best current option.
The Apple Dock connector doesn't seem to be a generically available item. However, RadioShack's iGo universal power adapter system comes with connectors for everything under the sun, including a B01 connector to fit the iPod. I've used various of these for iPod battery packs, needed for long flights. Also, to my ears the iPod line out sounds better when the iPod is charging.
Here are pictures of the B01 dock connector, wired for power only. The audio pins go on the other side. I'd agree with this pinout, except I could have sworn pin 1 is also ground.
Is it obvious to anyone what I should use as "needles" to add audio to such a connector?
Then I can follow your best advice, amply documented in other threads, for making an audio cable from there.
For power only I've stopped opening these up, which is a minor pain. Much easier to solder to the pins they provide. By the same reasoning it would be easier to do surgery on the Sik Din. However, I don't want the FireWire signal pins, which have to be treated with care. Everyone who has fried an iPod building a battery pack has done so by accidentally shorting or powering one of these signal lines.
