Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
Jan 26, 2013 at 11:05 AM Post #11,251 of 48,568
I tried three different cables of three different brands. No matter what, the PS3 freezes, and I have to unplug it and go through the error screen...
Trust me, it just doesn't wanna play nice with the receiver.
Jan 26, 2013 at 11:32 AM Post #11,252 of 48,568
Maybe you could pass through the PS3 video to still use USB, but select to use Optical for the audio? My entry-level receiver lets me select the audio source independently from video. Still think that, as proficient a semi-tech-geek you are, you might've overlooked something (like the OSD you missed earlier).
Jan 26, 2013 at 11:36 AM Post #11,253 of 48,568
Oh, I'm using the optical now. I have no problem there. I just really wanted audio through HDMI for less cable clutter. I don't think this receiver does the lossless DTS and Dolby Variants anyways. No that it matters, as I'm using headphones, and DH only needs the standard stuff.
I've tried all manner of settings. As long as HDMI audio is enabled, the PS3 freezes.
Jan 26, 2013 at 12:41 PM Post #11,254 of 48,568
When I get home I'm gonna lug my receiver upstairs into his room and try it. If I get a solution, I'll let you know. I really like puzzles :)
-Erik
Jan 26, 2013 at 12:57 PM Post #11,255 of 48,568
Did you try this?
HDTV Not Automatically Detected after Resetting Video Output Setting
With certain televisions, the PS3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above). If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
Connect both the AV Cable and the HDMI cable from the PS3 to the corresponding (AV and HDMI) ports on your TV.
Proceed with resetting the Video Output Setting on the PS3 again (follow the instructions above, and then continue to step 3).
Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
Manually change the Video Output Settings to HDMI (follow the instructions below, then continue to step 5).
Now switch the "Input" or "Video" channel on the TV for the HDMI port the PS3 is cu rrently plugged into.
Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the  button.
You can now disconnect AV Cable from the PS3 and the TV, as it is no longer needed.
[/quote]
-Erik
Jan 26, 2013 at 4:18 PM Post #11,256 of 48,568
I know this isn't a music thread. But since I have put the Annies away for resale. I pulled out my trusty CALs and have been listening to this mix. The bass in it is fantastic. A little bit of Dub, Electro and Drum and Bass.
HowlanDub on the Electronic thread posted it. All thanks go to him.
How I missed thick deep bass. I always love being reminded how awesome the CALs do bass with the HM5 pads on.
Sorry for derailing the thread.
Jan 26, 2013 at 6:04 PM Post #11,257 of 48,568
Well, yeah. The CAL is closed. An open headphone will never match the euphonic bass distortion of closed headphones. If bass was top priority, the Annie is definitely nowhere near the top. The Annie's bass is slightly over neutral, while the CAL and 990s are highly past neutral.
Youre comparing a warm, bass heavy headphone to a warm, balanced one.
Way different.
Jan 26, 2013 at 8:21 PM Post #11,259 of 48,568
Way different.
Don't believe I was comparing them. Just mentioned I was enjoying the bass after using the Annie's for the past week or so.
But since you crave a comparison.
The Annie is technically superior in every way except bass. it has depth and quality but lacks impact. The mids allow vocals to push thru in some cases maybe a little to far to the point of fatiging if you are not used to the sound. i also didnt find the soundstage and positional accuracy to be that hot i would get very confused at times. this was in halo and borderlands2. i am not having the same problems with the CALs.
Overall I wish I could keep them for stuff like portishead, daft punk, LOTR soundtracks anything where mids play a big part. Where they rest on my jaw line is very painful. I know now AkG in general is not for me due to their pad diameter.
With the Annie's I was hoping they would give me that out head feeling of the HD598 but they just don't. Could just be my head shape and ear shape that are causing the difference sound other people are hearing and I am ok with that. I want a DT990 with mids which I think is probably an impossible task. Hoping the HE400 helps towards that goal.
Sorry got long winded and this was a pain to type on my phone. :)
Jan 27, 2013 at 12:37 AM Post #11,260 of 48,568
Hello, I need a pair of headphones for gaming, I'm among the Sennheiser HD 419, Beyerdynamic DT 235, JVC HARX900 (btw, it looks very heavy), Superlux 668B and Samson SR850.
Thanks in advance...
Sorry, but the members here could help you alot better if we had more information. Try answering these questions
Price range?
Games that you play?
Do you want competitive or fun headphones (do you want to hear footsteps and know where gunshots are coming from, or do you want explosions to sound awesome)
Are you playing in surround sound?
And will these headphones have different uses?
I think that should help us a bit more to help you
Jan 27, 2013 at 12:47 AM Post #11,261 of 48,568
Price range is probably somewhat defined already given his current list (<$65), but yeah, answers to the rest of the questions would help in recommending one or two of those choices over the rest. You don't have to answer the third question in an absolute way, it's just to give others an idea of which way your preference leans.
The Superlux and Samson lean towards the more analytical/competitive end of the spectrum, whereas the JVC's got way more bass and possibly a fun immersion factor (more comfortable too IMO, tho they're very large). The Senn I haven't heard in a while tho I'd guess them to be somewhere in the middle. None are a bad choice if you're on a tight budget, just depends on what your preference or priorities are.
Jan 27, 2013 at 1:14 AM Post #11,262 of 48,568
So I spent some time listening to the Marantz with the Annie, and I'm pretty impressed by it's sound quality. It's definitely not as clear as the Compass 2 which is more neutral, but the Marantz adds a pinch more warmth, which makes the Annie a little more pleasant and forgiving. If the Annie is close to a Q701 with the Compass 2, the Annie is like an HD650 with the Marantz. Of course, that's a gross exaggeration, but that subtle difference is there.
I'm very happy with its gaming and movie sound quality, which really does best the Mixamp by a noticeable amount. It's that fullness, that lack of hiss, and less processed sound that makes it worthwhile. I'm still unsure on its DH being Room 2 or not, but having tested a few new demos like Sly Cooper, Dead Space 3, and Metal Gear Rising... the Annie and SR5002 is a pretty awesome gaming setup for sure. I certainly don't see the need to attach my Compass 2 to the mix.
Jan 27, 2013 at 1:37 AM Post #11,264 of 48,568
Just wondering what the output impedance is on it though. Receivers tend to have high output impedances which may be why it is warmer than the Compass 2. Still the AKGs and planar magnetics aren't hampered by output impedance like most headphones. I probably wouldn't recommend using a standard dynamic low impedance headphone on it, which might make the bass sloppy and treble harsher than normal. 250ohm and up would be a safe bet, aside from something like the Hifimans and K/Q/Annies.
Jan 27, 2013 at 2:06 AM Post #11,265 of 48,568
Yeah, might be an issue if you ever try out the Philips X1... Output impedance isn't listed on the specs anywhere?
Are you using this at your room/desk where you also had the Compass 2? Just curious whether you're gonna be using the SR5002 primarily for gaming and then falling back to the Compass 2 for music or what...
