Hey MLE, I had a question regarding mixing voice chat in from the Mixamp while using the Magni. Before you received the Magni you said:
I couldn't find if you had commented more on this, but after using the Magni now for a little while, did you find your above worry to be an issue, or can the Magni still drive headphones loud enough while mixing in voice chat via the Mixamp? I don't play multiplayer with voice too often, but when I do, specifically on Red Dead Redemption, I find I have to crank the mix knob to about 3 o'clock to be able to hear my friend loud enough over the game audio.
Also, I noticed in your amp section (the whole redesign looks great, btw!) that you mentioned the DT 990s can sound a bit harsh in the treble off the E9K. I'm still planing on getting the DT 990 Pros and was originally going to get the E9K, but if the Magni will treat them better and not have an issue once I mix voice chat in, then I'll go with that instead.
Thanks for the help!
Well my worries are mostly when adding voice chat, and not the Magni's ability to drive a headphone. The Magni should be fine for the vast majority. Just, dunno about driving headphones loud if you have a large tip towards voice chat on something like a Mixamp.
