- Mar 20, 2010
Oh Chico... I can always count on you. XD
The Fiio E9K is actually a lil more expensive here (€ 15), but I really would appreciate beein able to hook the E17 up to my MacBook if I wanna listen to some music or maybe watch a DVD. So it´s not like I need it ONLY to hook it up to the mixamp.
I also like the EQ option of the E17.
Would you agree that the E17 improves my overall experience with my beyers? I suppose I still could get the E9K later and connect it to the E17, right?
Only option my blu ray player (Philips BDP 3200) allows is "digital audio" on either "Auto", "PCM", or "Bitstream". I´ll have to set it to "PCM" or I hear nothing at all to begin with. There are also options that say "PCM-Downsampling" (on or off) and "Downmix-mode" (Stereo or Dolby Surround L/R".
Have no idea what the PCM-Downsampling does, but might the Downmix-mode be what I am looking for? I actually think it is...
Bitstream is for the optical/digital coaxial out. Don't know why you wouldn't hear anything.
In the description it says something like bitstream sends through the orignal track (DTS-HD) whereas PCM is for devices that do not support multiple channels. It always made sense to me that the Mix-amp couldn´t process the original DTS signal from the blu ray player.
Anyways, would the E17 be a good choice? Can I pair it with the E9K later on?
I'm assuming your connecting the Philips Blu-ray player to the Astro Mix-amp Pro using a coaxial cable?
First off, there is a new firmware update (Oct-15-2012) for your Philips Blu-ray player.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=nl&ctn=BDP3200/12
So far the best settings I can figure of for audio from the Blu-ray to the Mix-amp is setting the Philips for "Down-mix mode" for Dolby Surround.
I believe the Down-mix mode takes Multi channel audio and mixes to be able to send it thru 2-channels (using coaxial)
And I guess the Astro Mix-amp can then decode the Dolby Surround back to the Multi channel signal.
